need help downloading 477
Thanks murphdog I contacted my server, the problem turned out to be something with the signal being inconsistant, they fixed it from their end. I was able to download it & look at the timing, it is quite a bit decreased than the other map. I haven't had time to install it on the bike yet. I'll let you know how it turns out. Puma
I installed the map (#78 4.7.7) it made a huge improvement, no more knocking and better throttle response. I didn't compare any tables other than the timing tables, so I'm not sure what else is different. I have only ridden one tank but I don't believe it affected the fuel mileage------ mostly hiway 70-80 mph, some city, all 2-up riding----41mpg. Thanks for the info on the upgraded map murphdog, I would suggest anyone using #78 from the 4.6.2 version to try the 4.7.7 version. Puma
Here is a link to where I uploaded 4.77 to my Rapidshare account.
http://rapidshare.com/files/14187419...TUNER_V477.zip
If anyone has any updates to this, I will put them there as well..
Puma, glad that it worked out so well for you. I'll send your comments to my brother, maybe that'll convince him to try the new version map. I know my Dyna runs better with the v4.7.7 calibration 67 than it did with the v4.6.2. There's some stuff going on that you can't see in the tables when the software says "Updating OS".
thecabinboy
11-07-2007 07:32 AM
