Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Hey Guys; I want to attach a cigerette lighter plug to my accessory switch on my 2005 roadking . Any ideas on a good location for the plug and where to grab power from the accessory switch ? I'm trying to run power for my Gps. Thanks
For the GPS I suggest you use the aux switch, which is opposite the additional lamps switch. This switch is not used. You can connect the power cable for your GPS there. You don't need to run the cable under the tank....
