SERT Tuning 1
Location: Back in the Good Ole USA. South Carolina to be exact.
SERT Tuning 1
I have an 08 FatBob w/a J.E.T. AC and Rush Slipons w/two inch baffles. Using the SERT I uploaded a map that is close to my config \\; making a few minor tweaks, lowered the idle a bit, set the bias table to .750, and minor adjustment to fuel on decal to reduce deceleration popping. The bike seems to be running pretty good, but you know it’s difficult to compare to how it was.
SERT Tuning 2
Now, I got to thinking a bit. If I take my bike to an HD dealer and he puts it on a dyno to tune it, he really can only tune to ensure that it is running the best it can w/the current config within EPA requirements. If he were to really tune for performance, then he would be violating EPA regs and exposing himself and the dealership to fines and other problems. So my best bet performance wise would be an independent tuner. Am I correct in this?
RE: SERT Tuning 2
One other thing I had considered is this, the table I loaded had the 14.6 values and so is running the bike in closed loop mode. So, how is this map much different from the factory map? There could only be rather minor differences. Seems to me the biggest differences would be in the VE table.
Anyone care to comment on these thoughts?
RE: SERT Tuning 2
You mainly changed the ve of the engine so the biggest changes would be in the ve tables. You are loading a bigger charge into the cylinders so detonation is potentially a bigger problem so I would expect the advance to be retarded a bit to compensate. They built the map for HD parts so they are likely a bit more agressive on the fueling to aid in customer satisfaction.
RE: SERT Tuning 2
Generally tuning for max power is done at wot. It is hard to imagine that epa regulations are much of a constraint on power at wot. I do not really know though. Perhaps someone that knows what constraints the epa places on a tuner could enlighten us since it is a common theme.
RE: SERT Tuning 1
ORIGINAL: jluvs2ride
 \\;set the bias table to .750, and minor adjustment to fuel on decal to reduce deceleration popping.
RE: SERT Tuning 1
I just put the high flow filter on my bike so I have not had a chance to play with a map. I would suggest you start by trying to rebuild the ve table since you can check that for accuracy. There are some limitations to the logging and that will help demonstrate that point. The biggest advantage of a dyno for doing this calibration is the ability to create controlled test conditions. Wideband O2 sensors help even more. Without actually experimenting with it I cannot say more though.
WouldBeHD
05-15-2007 11:36 PM
