Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Hey I was wondering if anyone had any suggestions or similar problems. My 2007 FXST keeps blowing fuses when I switch on the high beam. When I hit the switch the fuse blows and then headlight doesn't work at all. Any suggestions?
find the answer to your problem yet?? ive got the same thing going on. im going to start troubleshooting next week, but if you have a fix that might speed things up.
Assuming they have no reason to change the colors on the wires across years/models the white wire is the high beam and yellow is low. Orange/white is the power and black is the ground. The switch is flipping the power from the orange/white wire between the yellow and white wire. The white wire is somewhere shorted to the ground, likely via the frame. Easiest would be pull the main fuse and use an ohm meter to check resistance between ground and the white wire at the connectors to find what section the short is in.
