Turn Signal
Turn Signal
I have a weird problem and I hope someone can give some advice.
I installed the Kuri LED light setup (tail, front and rear turn signals). I installed the load balancers according to the instructions and all seems to be working except the right rear turn signal. This is what happens:
Ignition is on, left turn signal (front and rear work properly)
Ignition is on right front signal works, rear does not blink, but is otherwise on.
Ignition is on flashers work (except right rear), when I turn the ignition off, all four flashers work correctly.
I've switched LEDS from left to right, same results.
