Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
My running lights are not working, but my headlights, brake &\\; signal lights work. Could this relate to a blown fuse or is this an electrical problem. thanks for your help.
if the fuse is blown then a wire will be most probably shorting out against the frame. I had the same problem... found a bundle under seat with wires grounding against the battery terminal. Tape 'em up and shove down.
