Charging question???
My wifes 03 Lowrider has stopped charging the battery. I'm unsure how to troubleshoot it. What kind of voltages should I have coming out of the regulator, and into the regulator from the alternator?
I know the battery is good, cause I put it in my bike, and it has worked fine since.
Any help welcomed,,,,,, Jay
RE: Charging question???
If you have a test light you can check your regulator by unpluging it from the stator and put the one end that you would normally ground on one side of the plug and touch the other side with the lighted end if it lights your regulator is bad if it dosen't it's more en likely the stator...
