Panacea lighting
Panacea lighting
I have a 2004 Ultra Classic, &\\; recently installed the kuryakyn led tail light &\\; red led turnsignals. I also installed the rear run turn control unit &\\; flasher. Everything seem to work fine at the start.
However, then my rear lighting went totally wonky. My signals lights at first didn't work, &\\; my security light went on (which I know can happen). Then every time I put my signal light on, everything flashed, both signals, tail light, etc.
I then unplugged the control unit, &\\; put everything back stock. My signals &\\; brake light now works, but my running lights don't. The tail light, lights on the storage unit, &\\; front fender don't work.
I assume the control unit probably shorted out, but not sure why my running lights don't work. The headlights are fine. Any help would be greatly appreciated. Thanks.
