SEST Connection to Bike for First Time
RE: SEST Connection to Bike for First Time
There are some glitches with the new SEST and you just found one of them. \\; Tell your dealer about it and they can send it back for \\;a new one, or get the p/n# from your ECM and see if the down load canned map will accept that ECM p/n.
I used 202td and changed the bias tables to 798. I hope this is close?
Doc1, I'm sure you may have some insight on "close", that is not hurting the engine until I get the 103 and cams in the bike over the winter.
I did notice that VE front was 80% at idle which tells me there is some room for improvement I think?
also notice that AFR states "14.6 desired" even with 798 bias tables? I guess it is "fooling" the ECU? Nightrider says 762 on the bias equates to 14.2..not sure what 798 is?
