fuelpac ver 12
Old 07-26-2008 | 09:11 AM
ductmate's Avatar
ductmate
Default fuelpac ver 12
hello all i have a question about my 06 deluxe with fuelpac i have a hiflo air cleaner stage one download and longshots hs not sure what the hs stands for? however the map is not listed on fuelpac website for my bike i was told to use the older map for the 05 the map is fp-0016 i did this and it seems to run great just have White spark plugs and heavy engine braking on decel also the inside of my new pipes are clean no soot i have put around 1,000 miles on the new pipes . is running the bike with white plugs a bad thing am i going to burn a hole in my pistons?
Old 07-26-2008 | 01:16 PM
glens's Avatar
glens
Default RE: fuelpac ver 12
The color of the tip of the center insulator is mainly an indication of the plug heat range. Look down inside for a thin soot ring on the insulator right where it meets the metal.
Use high magnification and look for aluminum deposits on the exposed parts of the plug if you are concerned about melting pistons.
gilbert_roadking
19
05-16-2016 09:16 AM
2011Iron883
03-27-2011 12:04 PM
60wt
07-06-2010 11:00 AM
ballgeier
06-08-2007 07:32 PM
Stel67
08-09-2006 05:34 PM
