PCIII and rain
Old 07-24-2008, 05:55 PM
2wheeltom77's Avatar
2wheeltom77
2wheeltom77 is offline
Default PCIII and rain
Heard they will fail if they get wet.&nbsp\\; Mine mounts in front of the mudguard, will get wet in the rain.&nbsp\\; Any comments?
Old 07-24-2008, 06:08 PM
TickTock's Avatar
TickTock
TickTock is offline
Default RE: PCIII and rain
Dont get it wet. It is an electrical component subject to failure, especially when wet... Use the plug to keep the usb connector from being able to draw in water and dry it out as soon as possible after it gets wet.
Old 07-24-2008, 06:50 PM
jandlcars's Avatar
jandlcars
jandlcars is offline
Location: NOMAD Milton FL Now Originaly From San Rafael CA
06 Dyna Wide Glide
First rain storm i got caught in bike backfired blew off exhaust
sent in for warranty took 4 months to get it back
Next rain storm died again took 4.5 months to get it back again
No more PCIII did not reinstall
Old 07-24-2008, 07:27 PM
2wheeltom77
Think I'm going to try to rig up a cover for it.&nbsp\\; No way a 9 day Sturgis ride will be dry.
Old 07-24-2008, 10:17 PM
glens's Avatar
glens
glens is offline
Not apples to your oranges, my 07 touring-family bike carries the PC-III under the side cover. I do not even have the port plugs installed, for ~14,000 miles and am not just a fair-weather rider, but never spray-wash. Nary a problem from weather/moisture.
I was inspecting the unit one evening, tracing wires to see which signals to/from the ECU were intercepted. The unit itself is an epoxy/gel-filled container with all the electronics encased. The USB and hub ports may indeed be susceptible to moisture entry, I will grant that. The port plugs seem as though they should be adequately effective for their task.
Old 07-25-2008, 05:44 AM
jkoch09ultra's Avatar
jkoch09ultra
jkoch09ultra is offline
My ultra has had on my 06 for 40,000 miles.&nbsp\\; Drove back from Daytona in heavy rain for 3 hours no problem.&nbsp\\; They need to be covered and kept as dry as possible.&nbsp\\; So far so good for me.
Old 07-25-2008, 05:46 PM
2wheeltom77
I was wondering about the unit itself, good to know it's sealed.&nbsp\\; The harness is at the top the way it's mounted, and I was wondering about that.
Old 07-28-2008, 10:42 AM
King_of_the_Road's Avatar
King_of_the_Road
King_of_the_Road is offline
Can
King_of_the_Road
not post
Old 07-28-2008, 10:46 AM
King_of_the_Road
more
Quick Reply: PCIII and rain
