Thundermax vs Daytona Twin Tec?
RE: Thundermax vs Daytona Twin Tec?
ORIGINAL: glens
The main difference is that the TMAX uses rpm/tps for both fuel and timing tables.
The DTT uses rpm/tps for fuel, rpm/MAP for timing. I feel this is the better setup.
ok... so i found MAP is "manifold air pressure"
i am guessing that you you feel rpm/MAP is better for timing because it more realistically represents engine loading under throttle?
thanks for response btw
My only experience with either package is via researching their documentation. I like the idea of using MAP for timing. I also get the idea that for most folks the software would be more friendly with the TMAX, but I use unix, not Windows, so my idea of friendly is entirely different. DTT seems as though it is more unixy than TMAX in their thinking. That, as much as the timing treatment is why I would go with the DTT. It is maybe why you would want to go with TMAX. Have heard some chatter about difficulty with pinging on TMAX, though...
The wide-band O2 sensors can always let the system make the fueling match what you wanted in both systems, regardless the current atmospheric environment. I do not know if there are issues with varying temperatures/etc. with the timing on the DTT. It gets discussed much less here than the TMax. Probably because DTT seems more geeky of the two and the general audience here tends towards wanting plug-n-play Windows-style type of stuff, which the TMax seems to offer them.
As I understand it, it is easier to do more fine-grained stuff with the DTT, but doing it is generally considered harder. Just like with unix. Most folks like fewer, less-confusing options.
ORIGINAL: trafficjams
ORIGINAL: glens
