map suggestions for pcIII
I have a 2006 Superglide with V&\\;H BSS exhaust with quiet baffles, SE stage 1 and pcIII usb. \\; When I got bike a year ago, it had alot of deceration popping and cracking and possibly backfiring. \\; Had it dynotuned and 95% of the popping and cracking is gone, but seem to have lost some performance too. \\; I got a cd of the maps and they are way different. \\; I also recently found out that the place I took it to is not a very good tuner for harleys!!! \\; Rode it that way since, but now want to try loading other maps with my daughter's laptop. \\; Does anyone have a similar set up and can suggest a Power Commander map or one of their own? \\; Also, do I need to load the other functions, fuel something or other into the power commander?
Thanks,
Larry in Ohio
Thanks,
Larry in Ohio
RE: map suggestions for pcIII
i bought my pc3 from fuelmoto.com. \\; it came pre programmed for my setup and pretty much ran perfect out of the box. \\; all i had to do was reset my throttle position but their map works perfect. \\; send them an email with your setup and location and they will probably hook you up. \\;
Go to Fuel Moto's web site. \\;\\\\\\;\\\\\\\\\\\\\\; You can look at instructions without a prior purchase. \\;\\\\\\;\\\\\\\\\\\\\\; Also go to Powercommander.com. \\;\\\\\\;\\\\\\\\\\\\\\; There you will find maps that might be closer to what you are looking for.
Electra1
Electra1
Stanger
07-26-2006 08:01 PM
