Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Twin Scan II and WEGO installed and powered up...I redownloaded the software from online....I can download from the Twin Scan, but the WEGO gives me an error message of "Script out of Range" at the end of the download sequence
If you are getting data from the the wide band 02 sensors through the twin scan program then everything should be OK. Have you done a test run to see if you are reading data from the sensors yet?
I did a test data run. The Twin Scan downloaded and I can access the results with no problem. When I try to download from the WEGO, I get the "script out of range" error message. Any other way to test?
