!update!-Bike wont charge battery
Well the other day i pulled the bike out of the garage to go for a ride, and the battery was dead. Very odd because the batt is only about 3 months old and it had only been a bout a week since i rode it last. Anyways i jump and go out riding hoping it will charge up on the ride. Well i did about 150 miles and still dead. We stopped a few times and had to push start it. So what would be the first thing to check? I dont know much about the electrical systems.
RE: Bike wont charge battery
With a digital voltmeter set to DC volts test the battery while the bike is running.If it is charging you should get at least 13 volts. Then check the alternator by removing the plug.Set the meter to AC volts.While the bike is running touch the alternator terminals with the meter probes. At 2000 rpm you should get 20 volts ac which will rise as the rpm is increased.If the alternator is working then it is a faulty regulator.
