Check engine light and PCIII
Old 03-11-2006 | 05:59 PM
fatheadonsoftail's Avatar
fatheadonsoftail
Default Check engine light and PCIII
Just installed the PCIII, V&H Big Shot and SE Air Cleaner.
Took it for my first ride of the season today and it runs great. No Backiring on decel and starts right up.
Only thing I now notice is Check engine light comes on for about 4 seconds after it starts then goes out and stays off.
It also comes on with key and goes off as normal but I never noticed it coming on when running before.
Does anybody elses do this?
Bike is a 02 FLSTC
Old 03-11-2006 | 06:18 PM
UltraScoot's Avatar
UltraScoot
Default RE: Check engine light and PCIII
ORIGINAL: fatheadonsoftail
Bike is a 02 FLSTC
Mine did the same after installing PCIII, its a code, I beleive it happen when unpluging the ecm to plug in PCIII. just need to reset codes and all will be good...
here is the link in the DIY https://www.hdforums.com/m_322770/tm.htm
Old 03-11-2006 | 06:21 PM
03 Softail's Avatar
03 Softail
Just posted a post on the same problem. Just took the bike out of heated storage ran it for several miles shut it off for gas/ lunch and a beer. Got back home shut the bike off.
Started it back up to put it away, same problem as yours with check engine light. Had my
computor reset 3 or 4 times last year, everything ok for awhile, put problem does come back.
Let me know if you have any luck finding the problem.
Dan
jorswift
05-30-2012 01:47 PM
jorswift
05-27-2010 08:12 AM
crazytrain69
04-10-2009 06:00 PM
Treek
16
11-10-2008 02:11 PM
Cruiser 1970
13
10-23-2006 12:51 AM
Quick Reply: Check engine light and PCIII
