PCIII and IED's
RE: PCIII and IED's
Well, power commander and closed loop is a mystery to me. \\; Within closed loop the ecm can target from 14.1 to 15.1 afr. There is little reason to doubt the ied's do as claimed with the ecm is targeting 14.6, but what it does when the ecm is targeting 14.1 is a mystery.
RE: PCIII and IED's
With eliminators, ECU thinks it is still open-loop-capable but all is well. No changes to AFV (from wherever it was). Is effectively open-loop-operation only, PC-III can then reliably provide modded fuel. It can also can alter ignition timing on the H-Ds. Best-compromise tuner, short of SE{R,S}T, DTT, TMAX.
