PCIII O2 elims
RE: PCIII O2 elims
I assume you meant you removed your O2 eliminators?
If so, there is a problem. This is most definitely something I have first-hand knowledge experimenting with.
Without doing some very fancy PC-III programming, you want the O2 eliminators in service (once you reset your AFVs).
RE: PCIII O2 elims
ORIGINAL: LilBudyWizer
Ah, that answers a big question I had about power commander.
This will really muck with ECU open-loop.
RE: PCIII O2 elims
ORIGINAL: glens
Umm, isn't that what I said?
So one guy says that leaving them in will mess up what the PCIII is trying to do, and another says that they are helpful. I'm confused [sm=WTFsgign.gif]
RE: PCIII O2 elims
 \\;Personally I agree with the others that say that not using the o2 eliminators will result in the engine not running as well as it should. With out the eliminators you will start seeing error codes show up. I doubt that they were included as a user optional part of the package but just to be sure, why not call Zippers and ask them?
Arcane
Arcane
