No oil pressure...
No oil pressure...
If this should be in the oil thread...let me know...
Anyhow, about 2 weeks ago a friend of mine came over and we started changing the oils in my bikes. \\; He took off working on the softtail..before I knew it, he took the crank case plug out and drained all that oil. \\; I put the plug back in and showed him the hose he was suppose to pull off to drain the oil. \\; After we put the oil back in, we fired it up and it ran fine. \\; Since then, it has drove ~150 miles with no problem. \\;
This morning I went to fire it up to go to work and the oil light came on. \\; I parked it and jumped on my other bike and ran to work. \\; When I got home, I took the sending unit off and hooked a pressure guage on it. \\; I fired the bike up and the guage never moved.
Oil pump I assume? \\; That much a PIA to change out?
Thanks,
Derek
Thanks,
Derek
