1550 downlaod on 06 dyna 1450?
RE: 1550 downlaod on 06 dyna 1450?
Wow... That is one that I would run away from...
No Tech, Let alone dealership should do that.....
That is a band-aid fix.... and a bad one at that....
I hope that you didn't shell out $$$$ for that.....
Bad thing about the 06 Dyna is that it doesn't have Adaptive Fuel....
Did they remove your o2's and use a load control dyno and Wide Band o2 sensors to CONFIRM and LOG these results?????
What is your Current 1450 build (Stage I Legal or Race), what style (8 or 25) injectors...
ORIGINAL: Shovelhead Bob
Yes, it is, BUT.... Why is it running that lean????
That is what has to be ID'd FIRST and Foremost.....
and again, HOW is that AFR verified......
They put it on the dyno (after I got a bit hot at them that they had it for two hours and didn't notice anything wrong on two test rides....) not bashing the dealer, they've been very helpful, but i \\;\\\\\\;KNOW when somethings lean and they probably thought I was just new to Harleys and was complaining about a rough ride.
Bike has 25 degree injectors and Harley script Slip-ons stock AC
i assumed it was bone stock when i bought it and had them put the slash cut harley script slip-ons on it because they said it would affect it enough to need a re-map.. but, with A/F's like that, I'm interested to see if the previos owner put an A/C in it and didn't tell anyone when he traded it in.
BUT...in retrospect, as quite as those stock 06 mufflers were, atting those slip-ons might just have whacked it out, especially with a non adaptive fuel system
going to pick up the bike tonight, will ask to see dyno logs
freebyrd
07-07-2008 11:57 PM
freebyrd
07-03-2008 03:30 AM
