What should a good tuner do exactly?
RE: What should a good tuner do exactly?
CR
If you make that many changes like going to duel intakes and MAFs that would require a MegaSquirt. That is almost exactly what I did on my jetski. The MAP \\; and IAT has to be pulled out of the fueling equasion and the VE table would require VE numbers out of the range that TTS and Harley allow you to get to. Good tinnking out of the box though. \\;
The vibration of the Harley may be a little hard on the heated wire version of the MAF. We are going to look at the new Ford "credit card" MAFs
Here is an older shot of my ski. The Ford MAF now sits right where the brass tubing is in this shot.
AW
AW
Z
11-19-2018 12:21 PM
Tampakingpin
04-30-2013 06:55 PM
Heatwave
07-14-2010 10:19 PM
