883C engine smoke?
883C engine smoke?
Hi there,
I'm planning to get my first HD. I've got my eyes on a 04' 883C and went to the dealer to check out the bike. It's in a mint condition with only 8xxxKM mileage.
But one problem puzzle me is when the shop keeper starts up the bike, I saw some smoke coming out from the engine. It was just a cloud of smoke and then nothing more, the engine sounds right and all. He explained it's because the bike's not started up for a long time and it's normal for it to smoke up a bit.
Is it really normal for a bit of smoke coming from the engine when it's started after a long time of idling?
The bike: http://www.kcchk.com/Pictures/5001.jpg
Cheers!!!!
Cheers!!!!
RE: 883C engine smoke?
There isn't a check for a bad seal except if it smokes.....if the bike only puffs a bit of blue smoke on start up most likely the intake valve seal leaked some oil by it and rested on top of the valve or piston....if the bike isn't burning oil while it runs I wouldn't worry about it. I just hate it when dealers say things are normal when in fact it is not normal...the only thing normal is the dealer saying things are normal....lol
ORIGINAL: calfunk
Thank you so much doc. I will definitely ask the dealer about this. Is it a big problem or it just needs a simple fix? Should I still get the bike?
I wouldn't let a little puff of smoke keep me off a new bike....lol.....no big deal if that's all that's wrong with it. \\; You could ask if they will replace the seals.
Black smoke would be a good sign that the bike has been sitting and is nothing more that that, most bikes will billow out some black smoke if the engine spins over a few times and the enrichener is in, doesn't sound to me like the engine needs to be tore down. sounds normal....
