EFI
RE: EFI
When an EFI part fails and needs replacing....that part is usually very expensive. The really nice thing is the onboard check engine light though....as it can help lead you in the right direction on to what is wrong.
I'll take either an old Bendix, CV carburetor, or an S&\\;S Super E.....when it is time to work on it though.
Actually though, the Harley EFI systems including the Magnetti Marreli is pretty reliable.
RE: EFI
I'll admit, I'm new to Harley Injection.. However...
Ive been tuning injection for 10 years now on turbo charged RX-7's...trying to tune a turbocharged, rotary engine by mucking about with carberators would be lunacy IMHO..
Anyway...tuning injection is FAR easier (work wise at least) than working with carberators....You hook a computer up, put the vehicle on a dyno and hit some keys...
AND THERE is ALSO the problem....95% of the people out there do not have the EQUIPMENT nor the KNOW_HOW to propery tune their own system...
AND... the MoCo and the dealerships guard the info like super-secrete squirrel droppings.....
Back in the old days... you bought a set of pipes and they came with a set of jets for the carberator (well, not always, but you get my point), there had been so much research done, that they pretty much had the re-jet thing down to a science....
That aint happening now!!!
THe goopd news is that companys are catchin up...For example...Vance and Hines have been doing a lot of legwork in this area, if you buy a set of V$H pipes and install a high flow airfilter, you can also buy the V&\\;\\\\\\;H fuel pak and dial in settings found on their website that will compensate for the changes and re-tune your bike..
Finally...... I know guys that bitch about how complicated injection is.....but, these same guys took their carberated \\;\\\\\\;\\\\\\\\\\\\\\;bikes in to the stealer to have them re-jetted after a pipe change, so whats the difference now.. they still aint doing the work!!!!
