Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
While I was surfing thru my DTT log data, I wondered just exactly what is the ideal head temp? \\; Mine is hanging around 110-120 at constant hwy speeds of 70-75mph...
Sorry, I was a bit vague there.... \\;\\\\\\; 110-120C, or 230-250F..
I'm utilizing the stock head temp sensor thru my DTT programming, which is located on the front cylinder head beside the intake port.
Thats about the same as what I am getting on my 07 UC. What does you knock sensor data look like? I had to take 2 degrees out at 2500 RPM at about 15 % TP.
If this question is directed to me, I wasn't aware I could access knock sensor data.. \\; I do have pinging from 2 to 3K. \\; I have pulled on degree so far and richened up the mix. \\; The pinging is gone from 2.5K up now at full throttle, so I'll try pulling another degree from 2 to 2.5K.
