How do you retreive 2006 Dyna trouble codes
RE: How do you retreive 2006 Dyna trouble codes
have the same problem after installing the TFI. what did you do to fix the P0151 error code?
checked all the wiring, and all connections are good. see that the code indicated a lean rear 02 sensor. i verified this was correct. the front spark plug is a bit rich, however the rear is definately running lean.
Look in th DIY section of this forum...Check this link for codes https://www.hdforums.com/m_327240/tm.htm
HDF Tech
03-12-2006 09:07 PM
06, 2006, codes, dyna, engine, glide, harley, harleydavidson, harleydyna, low, rider, super, trouble, ultraclassic, wide
