Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I just replaced my voltage regulator today. \\; If you are not getting 14 VDC at the battery with the bike running, the voltage regulator is not recharging the battery. \\; See the electrical check 1 1nd 2 in the DIY in electgrical.
ok! i made the checks as per the elect. part 1 and 2 diag. i am getting 16v at idle at the stator plug. the volts goes up as i rev it! i think it is the regulator. i am still a bit confused due to the fact that i have 3-pins!-BRIAN
