Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
2006 FLHTI 5500 MILES, TWICE NOW WHEN TRYING TO START IT JUST CLUNKS BUT WILL NOT TURN, BATTERY VOLTAGE IN SPEC, TRIED ROCKING BACK AND FOURTH IN GEAR, NOTHING, PULLED PLUGS TO MAKE SURE NOT BOUND UP ALL WAS FINE! FINALLY HIT IT WITH A BOOSTER PAC AND IT STARTED TO SPIN, REMOVED BOOSTER AND WORKED FINE FOR ROUGHLY A MONTH, THAN AGIN THIS PAST SAT. AM DID IT AGAIN BASICLY SAME DEAL, CLUNKS REPEATEDLY AND AFTER MANY TRIES IT STARTS SPINING AND HAS BEEN FINE SINCE???? ANYONE ELESE FIND THE RIGHT CURE FOR THIS? THANKS FOR YOUR RESPONSE! WD
battery was swaped with a new one from another bike, sorry for not stating that, but the other battery was load tested and passed fine, also no problem starting other bike! It appears to be a jackshaft or over running clutch issue I think!
make sure you ohm your battery cables then if everything is ok more than likely a selenoid issue if there is nothing wrong with the jackshaft assembly,as if it were a starter clutch it would spin but not turn the engine over.
