Does Anyone Know The Answer To This ECM Question?
I have a 2007 FLHX with Rinehardt true duals, Big Sucker air breather,Vance Hines fuel pack. The bike has been intermitently stalling when coming to an idle. To rule out the Fuelpack I unhooked it and reconnected the stock ECM. I have always been told the bike would not run very good,with the stock ECM,True duals,and High flow air breather. It seems to run just as well with the stock ECM as compared to the Fuel pack. Even the plug color is the same,no pinging,coughs or stumbles. If this closed loop system is like my cars closed loopcomputer it should compensate for change in air intake flow,temperature,as well as exhaust temperature. So like my car when I install headers,exhaust and cool air intake it will compensate. Are We Being Scammed by Vance Hines,Screamin Eagle Race Tuner,Cobra? Can anyone answer this question?
RE: Does Anyone Know The Answer To This ECM Question?
More or Less you are right. The 2007 and Up bikes will adjust via their O2 sensors for most changes you do. However, a lot of owners are trying to make the bike run cooler and make more horsepower. The IED sensor modifiers look promising. They fool the Stock ECM to run richer so the bike will run cooler in closed loop mode. Not really a scam you just need to understand what you are getting.
ORIGINAL: wallyn
GPM
Honestly I have not really thought about it all that much because I own a Pre-O2 sensor bike. There is a long thread about the IED's and I have only glanced at it. I am beginning to think that the stock ECM really is not all that bad when cruising it is the SLOW parade riding, traffic and idling that sucks on it. As long as you are moving I think you are fine, which is why it is legal to split lanes in California BTW.
Bobber Rider
07-09-2006 02:38 AM
