canned map 100 OR 101 SUPER TUNER
CALIBRATION # 100 OR #101 ON SE PRO SUPER TUNER. HAS ANY ONE RUN THIS YET, ON AN 08 BAGGER?THIS CANNED MAP IS JUST A START BUT HOW DOES IT RUN? IT MUST BE COOLER MORE GAS.
CALLS FOR
SE AIR CLEANER- BIG SUCKER
RACE EXHAUST -RINEHARTS TRUE DUAL
THANKS FOR THE HELP
CALLS FOR
THANKS FOR THE HELP
RE: canned map 100 OR 101 SUPER TUNER
First off, WELCOME ABOARD.... Post an intro in the New Members Section....
Second... Turn off the Caps Lock.... We can hear you just fine.....
If you are using the SEST (Super Tuner), the map you need is 202TD002....
If you are using an SERT (Race Tuner), then you need to use 200TL001....
The maps are completely different, and are ONLY a starting point...
Those maps were designed for a Touring Headpipe system, and NOT TRUE DUALS....
It will get you by for a little, until you can get it dialed in by a competent and reliable tuner.....
oldgraybeard
06-16-2009 05:11 AM
