tmax help!!!
It overwrites the existing map.Link up andsave the one you have now and stick it into the new folder option using the normal designation and only change the last few date numbers, should it be better than the new one you install. Next,clear learned offsets,clearlearned iac. These are stored in the module, not the map and must be removed prior to any map load. Write the new module maps and settingsyou have chosen to the module. Check the module basic settings and closed loop settings and make sure they are correct for you bike.At the bottom of each of these pages there is a write to module selection. DO NOT forget to do that. Go through the initialize thing of 30 seconds on and 30 seconds off 3 times, bring it to 285 and shut it down . Unlink, and go ride.
I realize the tuning manual is a pain in the *** to sift through, but it's all in there.![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
Ron
Ron
It helps if you have the 8 page installation guide. Steps 4 - 11 will get the job done.
http://www.thunder-max.com/Support/I...onManuals.aspx
In short the processfor installing a new mapis this (assuming you already know which map you are going to load):
1. Connect the laptop/ Open the software
2. Turn on the ignition and kill switch
3. Click on Link, wait for green light
4. Under the Map Editing Menu, Clear Learned Fuel Adjustments and Learned Idle control Adustments
5. Close the map that is open.
6. Pick a map using steps 3 & 4 of the guide.
7. Load the map. From the toolbar, click [File] [Write Module Maps and Settings]
8. Verify Module Basic Settings. Before performing this step, clear any active Diagnostic Code readings. While linked, from the Tuning Tree select [Module Configuration] [Diagnostic Codes].
9. With the handlebar switch in the ‘ON’ position, cycle the key switch on and off 3 times, leaving the ignition on and off for 30 seconds each cycle. DO NOT start the engine or move the throttle during this process.
10. After 3 on/off cycles, start the bike 2 times, letting it settle at idle for 10 seconds; the idle should be smooth and steady.
11. Without touching the throttle, let it run until it reaches 285 degrees (you should still be linked so you can click on monitor to see the temperature gauge).
You're done.
Rick
You're done.
Rick
ORIGINAL: JustLoafin
What if I just want to tweak the existing map?
Ron
