Weird Gremlin
Weird Gremlin
I washed my bike very carefully (did not want water getting where water is not intended). Went for a ride the next day and the check engine light came on, the fuel light came on, the security light came on and the speedo went dead. Figured I was not careful enough washing. Stopped, restarted the bike, everything is OK. Fast forwared three weeks. Have not washed the bike and the day is warm and dry. Go for a ride and the same thing happens again. Stop, shutdown, restart, everything is now OK. Planning on having a talk with the dealer, but have the feeling this is going to be one of those elusive problems. I don't want to hear it is not a problem, any time a warning light is not working properly, it is a problem in my book. What are the opinons out there of what could be causing this?
RE: Weird Gremlin
I had a problem with my 2000 Ultra where the check engine light would come on after riding about one block. i couldn't see why. On my bike you can clear the trouble codes by holding in the button on the odometer while turning on the Ignition. I had to take it to the HD dealer and they found that the battery cable connections at the battery were slightly loose. It would still start and run OK but would throw a trouble code shortly after riding a little ways. The mechanic said he never saw that before. Anyway now it is fixed and no more check engine light coming on. So check the tightness of your battery cable connections. That may be it.
Good luck
Good luck
