Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Careful... get the highest cold cranking amps you can find, and still good luck with it. I know a lot of people have good luck with Autozone batteries etc.... but not me... only HD batteries will crank my 86 Evo over.
Sears Kmart and Oreilly auto parts sell an AGM battery that is 285 CCA (cold crank amps) it's not much less than the HD and starts my 11 to 1 CR shovelhead...
I think Drag Specialties top batterry is 310 CCA.
good luck
I think the one I bought from Wal Mart was only 270 CCA.... 285 would probably work for you. My dad's RK is a 2004, and the original battery just died. He uses a battery tender or trickle charger (or whatever it's called), but it still died.
