Cig Lighter Inop
Old 05-20-2008, 01:05 PM
JeffreyB's Avatar
JeffreyB
JeffreyB is offline
Default Cig Lighter Inop
The cig lighter on my 08 Ultra quit working. Changed the acc fuse (fuse was not blown). Still will not work..Anyone see this prob before
Old 05-20-2008, 01:09 PM
Malac Frost's Avatar
Malac Frost
Malac Frost is offline
Default RE: Cig Lighter Inop
check the maxi fuse? just a suggestion.
Malac
Old 05-20-2008, 01:13 PM
diebolt's Avatar
diebolt
diebolt is offline
Did you try the lighter in another vehicle?
Maybe the lighter went bad.
Old 05-20-2008, 01:21 PM
JeffreyB's Avatar
JeffreyB
JeffreyB is offline
As far as the Maxi fuse..Wouldn't other electricalsystems be affected if it was blown... Also good idea about checking the lighter in another vehicle...What I should have added was that I was using the cig outlet to power my GPS... So I checked the outlet with my cig lighter and my GPS and my Sirius radio and none of them worked...Next step I guess is to pull the Fairing and look at the back of the plug
Old 05-20-2008, 01:52 PM
diebolt's Avatar
diebolt
diebolt is offline
Yes I would check in the fairing. Maybe they have an inline fuse to the lighter back there.
Old 05-20-2008, 04:01 PM
adlerx's Avatar
adlerx
adlerx is offline
Same here. Went inside the fairing and no juice to the wires. EVERYTHING ELSE WORKS PERFECT! Next time inside I'll rewire it so I can have the port if needed.
asherdav
06-17-2015 12:07 PM
Betteroff
2014-2023 Touring Models
06-09-2014 07:59 AM
alandchris
01-18-2009 07:22 AM
exWinger
03-12-2008 09:01 PM
capt42a
03-30-2007 07:13 AM
Quick Reply: Cig Lighter Inop
