speedo/tach swap
speedo/tach swap
Hi all, just a quick question. I have a 2001 RKC. I am trying to install a speedo/tach combo. I did locate the pink wire under the tank. This pink wire has a plug end. I have an empty wire spot #6, on the plug harness that will plug into the speedo/tach. Is there a wire that can be bought? The problem I see is that the end going into the plug( the on that plug into the combo), has to be a very small connector. I would appreciate any ideas
thanks, and watch for other when you ride.
jimstem
08-23-2019 09:09 PM
