Brake Light Problem
Brake Light Problem
Just got the stock radio up and running on my 86 FXRD. When I use the rear brake, at the point the brake light switch activates, there is static on the radio. If I push the brake pedal further, the static stops. Could a bad brake light switch cause the static. Does not happen when front brake only is used.
silvertex1
Electrical/Lighting/Alarm
08-12-2014 01:17 PM
