Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Well I'm getting close to having my 10K service and I noticed that part of this service includes changing the spark plugs. So, I was wondering should I stay with the stock plugs and wires or change them to another type? If another type, what does everyone recommend? I heard some people mention a lower temp plug and I've also heard it's not a good idea to change the sytle plugs. Any help, as always, will be greatly appreciated. Also, for a little info on the bike: Stage 1 AC, 3" Slip-on's, and dyno tuned.
Give a thought to using your present plugs another 5-10k. If they show no signs of deterioration go with them a while longer. I've never had any problems doing it this way.
i went with SE triple plat, basically a Splitfire re-branded. they work great, also went with Taylor leads at the same time. I checked the plugs after 2.5k and they were as new, no deposits at all, nothing, nada, zip
Needed to check my [2007 dyna] service manual, couldn't rememberplug requirements at 10k. Says inspect at 1k 5k ---15k 25k, replace at 20k. Plugs looked fine on my LR at 10k.
You spend 18 grand for a bike, what is another 5 bucks for some new plugs?
I'm with you. I'm not asking should I change the plugs, but what plugs should I get.
Sorry, I was referring to the go another 10k on the ones you had. I would think that the stock ones would also be the type to use as well going forward.
Thanks guys. I think stock is the way Im going to go. One other question, though, if I bought the platinum tip plugs is there any benefit other than longer plug life?
