Anyone With IEDs/XiEDs Still Getting a Little Surging?
Anyone still getting a little bit of surging at slow speeds or decelwith steady/light throttle? I've got a SERT with my O2 bias tables maxed out, which is the same effect as the XiEDs, and I still get a little surging with the SE mufflers,less to no surging with the stock mufflers. The improvement of the SERT is awesome but the slight surge is still there on very light or decel loads.
I love the added sound of the SE mufflers but the slight surge is annoying.
Anyone with the IEDs notice the same thing?
RE: Anyone With IEDs/XiEDs Still Getting a Little Surging?
sorry no one's answered your question. I'm about to install a set of V&H slipons and XiEDs on Sunday. I'll be curious to see if I experience the same thing. I'll post if I do.
[IMG]local://upfiles/38807/89FBC457CAA245E5B4854E9534E208E4.jpg[/IMG]
I have not had any problems with them. Check my sig pic info for what I am running. The bike is running very strong and smooth with my set up and XiED's. I'm sure as with any fuel management each person will get different results based on their set up. That being said I think that over all you can't beat the XiED's for cost and final results.
I have the IEDs installed. I get surging when I first start out. I believe this is due to the engine not being fully warmed up. I let the rocker heads get warm to the touch; but still get surging when I start out. After the first few minutes riding, no surging. So, I don't thing the surging is because of the IEDs; but I could be wrong. This morning I let the bike idle while I checked out of the hotel and put on my helmet, gloves, and rain gloves; I still had surging but only until out of the hotel parking lot.
OK, put my XiED's on along with V&H Oval slip ons. All I can say is WOW, does it sound better.
No surging noted but idles kinda fast.
Put a bead of Permex Ultr Copper on just because ahd re-used HD clamps. Broke both arms tightening them down but no leaks/no decel popping.
It may be my imagination but it seems a little less aggressive when pulling through the lower gears. Maybe my imagination???
Also put on the Mini Beast-nice sound!!! One thing though, the directions show slipping the wirs under a frame suppor, BUT there is no way that can be done on my 08 RK. Had to improvise but all worked out in the end. I REALLY like my 08 RK now.
[IMG]local://upfiles/38807/042AD384A89C41FCBE7EA56982EBF1D3.jpg[/IMG]
badbs101:
The best person to help you with the SERT and XIED set-up is Rider57. PM him and I'm sure he can help you with the surge.
bezoar:
You might want to try and re-set your FBW throttle. Usually with the IED's or XIED's, your idle will go down. Some times when you shut it down, if you have your hand on the throttle or rev it a bit when you shut it down, the FBW thinks that that's where zero on the throttle is.
With the kill switch in the "Run" position, turn the ignition from "Off" to "On" 4 times with 3 second intervals before going back to off. This will zero out your FBW throttle.
Try that and see if your idle comes down.
bezoar:
After reading 39 pages about these devises and learning about the "closed loop" and "open loop" on my 07 fxd I use both-- the Xied which covers the closed loop and fuelpak which covers the open loop part of the efi. I have no hd download which I understand would cover the open loop of the efi. ---Instead I use the fuelpak for open loop coverage. Hope this info helps and is not to confusing.
columbia whaler
11-16-2008 10:36 PM
badbs101
05-18-2008 09:35 PM
