Just got my Twinscan II Plus w/wego
RE: Just got my Twinscan II Plus w/wego
ORIGINAL: Tltrump
I am making a sniffer but should I have the bungs welded to my pipes so i can ride with the sensors to aquire tuning data?
One thing I learned is that the Daytona Manualstates that you do not need to set all AFR Target Values to 13.5 for tunning. I tried this and was not getting anywhere, this may be due to the fact I have an Open and Closed Loop System. This being said I need to change all AFR to 13.5 to get the bike to run in Open Loop. Once this was done and I put in the correct VE correction to the map.
I'm using a SERT but I noticed the table above the target is 13.5
Yep, I have mine tuned to a flat 13.5 right now. Not perfectly, as I could prolly pick up some more data points w/more logging. I may hook the TS/WEGO back up & tune 60%-100% TP's to 13.2 someday, butthe bike is running very smooth & I'm satsified w/it right now.
VicW.
VicW.
