Fuel spraying inside of tank??
05-10-2008, 02:11 PM
Is that normal?
I have an 08 RKC. It's been a littleslow tostart lately but runs ok andgetting great fuel mileage.
I had read in another post, thatI can't find anymore, thatmade a comment about apossible fuel pump problem and said that it was spraying inside the tank. Out of curiousity, I opened the cap while the engine was runing. It looked like a driving rain storm inside the tank.
Any thoughts or commentswould be appreciated.
05-10-2008, 03:50 PM
RE: Fuel spraying inside of tank??
Possibility of a bad hose or clamp on the hose inside the tank.
05-10-2008, 09:28 PM
V-Rods have a known issue with the fuel flange breaking. The pressure hose will back spray a mist into the tank that is easy to see with half a tank.
They will start stumbling at high throttle.
Don't know about the Road Kings, tho.
05-12-2008, 11:34 AM
Can`t say about any problems with 08`s but the older bikes use to have problems with small pin holes in the feed line to the fuel bung.
05-12-2008, 02:26 PM
Yep you got a problem in there better take it apart and figure out what it is soon before you find yourself stranded.
05-12-2008, 05:10 PM
Bring it back to the dealer since it's under warranty and let them fix it.
05-13-2008, 09:25 PM
Thanks for the responses.
Took it in today and they found a bad oring on the fuel filter assy.
Of course they didn't have it a stock and it was too late to order today. Get it back Thursday.
Rebelwoc
06-03-2018 05:22 AM
High Roller
03-14-2015 07:07 PM
billatstarbrite
02-27-2014 01:59 PM
DRated
05-09-2013 11:51 PM
mulch63
05-11-2009 07:14 AM
08 ,
2008 ,
davidson ,
fuel ,
harley ,
harleys ,
hose ,
inside ,
king ,
road ,
spaying ,
spray ,
spraying ,
sprays ,
tank
