07 dyna lunges forward on startup
Hey everyone. I've searched all morning because I remember seeing something about this issue and a possible fix. My 07 street bob will lunge forward on startup occasionally. It seems to do it more often after a ride and it then sits for a bit. It has done it before right after a fuel up tho. Is this a timing issue?
I'm currently running a tuned stage 1 setup with CS muffs, SE A/C, and SERT with "custom" map. Can anyone help?
Thanks.
Thanks.
RE: 07 dyna lunges forward on startup
Take it to the dealer/stealer. Maybe a clutch cable or the adjusting rod behind the derby cover needs adjusting or there is something wrong with the neutral position.
If you are doing the adjusting yourself get the service manual if you don't have one.
Actually the guys here are telling the truth.....start it in netural. The 07 line of bikes have the auto primary chain adjuster and in my persnal opinion they run the chain too tight which puts a bind on the clutch hub and gives it a draging effect.....it will get worse as the primary case expands because the chain now gets tighter and the clutch hub is binding more. Even with a good adjustment this is still going to be an on going problem and if you have a little too much run out in the main shatf it adds to the problem, so again start it in netural and it won't jump or lung at all.
BTW I'd say your timing is fine...lol
HDRider103
09-04-2017 06:44 PM
TexasMotorcycleRider
2014-2023 Touring Models
29
05-06-2015 08:17 PM
