Bike stumbles under power
2003 SE Deuce with only 2200 miles
Rush Slip ons and PCIII from FuelMoto - otherwise stock
Yesterday the fuel pump fuse blew. I replaced it and now the bike stumbles like it is runnning out of gas. It idles fine and drives okay for the most part. It does not stumble more when accelerating, as I might expect if the fuel pressure was low. I only drove about ten miles since. I was pretty far from home but only a couple miles from a dealer, so I dropped it off. I haven't heard back from them yet but I prefer to fix my own vehicles. So, I am working on a Plan B in case I am not comfortable with their response.
I have had the bike a couple months and have put 800 miles on it with no problems until now.
RE: Bike stumbles under power
Cicero: It may be a simple as resetting the ECM. Not sure how that is done with the PCIII. With the stock ECM: "Try cycling the power 4 times with the throttle grip in the idle position. This allows the ECM to relearn the zero postion of the twist grip sensor. Then make sure your throttle grip is not sticky...which can cause issues if it doesn't return to the zero position every time. It can also learn the wrong position if you shut your bike off with the run stop switch...with your hand on the grip. "
A 2003 Duece with only 2200 miles. You probably have a fuel pump issue. Fuel is pretty crappy now days. It will start to varnish and gum almost as fast as you pour it in the tank. THe new 5 - 10 % alcohol levels in today's gas is just enough to loosen deposits and clog up the works even more. There is a thread on the forum about changing the fuel pump and the fuel filter.
If you do not ride very often you should add some type of fuel stabilizer to the tank every fill up.
Good Luck
Good Luck
cwsharp
03-13-2009 03:13 PM
clueless
11-27-2006 10:31 AM
