Check engine light question for a 08 Ultra
I just loaded a new map into my 08 Ultra. The check engine light comes on when the ignition is turned on for 4 seconds as it normally should per the owner's manual. It will go off and after about 1-2 seconds the light will come back on and stay lit for approximately 10 seconds. Then the light goes off and does not come back on.
Any ideas why the light is coming on for the second time? It didn't do this with the original map.
Thanks
Thanks
