how to install pcIII under seat
RE: how to install pcIII under seat
if its like mine and wont go where the dynojet instructions tell you to put it because the alarm is there ( under the ecm ) then under the seat you will see a main span that the ecm bolts to from the top of the fuse box panel, cut the arm off and place foam under the ecm to support it, although the other mounts are enough. then cut off the small tab on the battery box where a couple of plugs are push fitted into, relocate these plugs under stock ecm ( i also wadged a large pieces of foam towards the front and rear of this area just to make it all snug for the PCIII ). the PCIII will now sit under the seat quite happily and if you have a LePera barebones the carpet on the underside of the seat makes another soft layer to protect the commander unit have pictures if you want - pete
