Help tweaking my SERT map
I got my bike Dynoed last week. I'm extremely happy with the numbers it pulled and how it rides. I just received my SERT map from the person that did the tune and reviewing it, I ask myself if it could be better.
My question is, if I post the dyno chart and SERT map, is that enough to manually "polish" the map and re-upload it? Let me know and I will post both.
Cheers.
Cheers.
RE: Help tweaking my SERT map
That's so right.
Everything is a varitable. Every little thing is going to affect many other things. Unless you have some feedback, a dino or just (knowlegable) seat of the pants, one can get all messed up playing with these numbers. And whoever is adjusting things reallymust know the process. That is the mechanical engine process, and the fuel injection process combined. Ain't rocket sience but you gotta understand.
It's one bike at a time. Gotta think it through.
I actually think HD does a good of getting started with the SERT Cals, at least. I would like to see a better selection of their cams.Moreof the torque ones.
If your tuner is any good, (Which I'd say they probably were or you'd never gotten a copy of the map from them)you have gotten all your going to get. Why would you want to mess with the map after you paid good money for it be be custom made for your bike? If your having a problem, or need any adjustments take it back to the tuner.
ORIGINAL: ericsenf
Cheers.
Cheers.
ORIGINAL: oldfartjc
Lets see, it ain't broke so why the hell do you want to fix it. You paid good money to have it Dyno tuned so if you're extremely happy then leave the frickin' map alone.
But isn't that the nature of hot-rodding - fixing stuff that ain't broke?
Ok Eric, I got your map and went through it all, I can tell your tuner went to the MoCo school by the changes he made and where the changes where made. All-in-all he did a good job but I too question those couple of areas you questioned.....I will send your map back to you with a couple small adjustments but I need to know some information from you so call me tomorrow (Friday) Between 9:00am and 3:00pm Florida time.
Doc
Doc
Hi Erick,
As long as you have the origional settings of the map, you can play a little if you want. Learn how to use the data recorde mode and analize what the results mean to your riding style and the results you want. The map for a drag racer will look a little different from one made for two up crusing.
Just that Doc has made a few minor suggestions as to changing it tells me that the tune, while producing really great numbers, may not be the best for your style of riding.
Best to all.
Pixs
Best to all.
Pixs
lt1tyrell
10-24-2010 04:20 PM
