Cruise Control Error Code 112
My cruise control won't engage on my 2003 electra glide (FLHTI). My bike is a fuel injected model.Ichecked the Cruise Control Diagnostic Codes and received a 112 Throttle Roll Off error code. I re-ranthe cruise control initialization proceedure and it completed without problem. The cruise lamp lit up and engine ran up and adjusted the lash. The bike also seems to be running a bit rougher than normal meaning I'm getting popping and backfires when I roll off to shift on deceleration.Not sure if this is related or a seperate problem.Prior to this last weekend everything has worked normal. No changes or mods have been made that could be attributed as the cause. Any insight/help is much appreciated.
Inta
