SERT question ??????
I would like to purchase a MAP from Latus for my intendedset up.
Can I use the Race Tuner software CD p/n 32117-01J and the Race Tuner p/n 32107-01L together to downloadthe MAP????
If not whatsoftware p/n CD do I need?????Letter designation?????
Unfortunately The "L" does not include CD or Cables.
RE: SERT question ??????
If Latus is using the newer software, 32117-01L or 32117-01N, to create the file, your J won't open it. The cables and dongle fromany version of the kitwill work fine. You can download the N software here. http://www.sendspace.com/file/q7d973
Murphdog, Much Appreciated. Downloaded and unzipped. I will look thru the software manuals tomorrow.
I have two options:
1. A MAP from Latus, 50.00
2. The dealer has a MAP but they want two hours labor. 160.00 ish / And I need a richer MAP to get me to the dealer. I was thinking MAP 78 to get me 25 mile if I choose the dealer.
I have two options:
Calibration # 78: 2007 Touring Exhaust with O2 Sensors
Configuration: 1580 SE A/C & Race Exhaust
File Name: 176PZ005-A0.MT6
Components:
• 25deg Injectors P/N 27709-06
• SE Air Cleaner and Breather Kit P/N 29440-99C
• Race Exhaust
If Latus has a map for you're setup, Mike will let youknow which version of the software you need, most likely 477. A download link to version 477has already been posted in this thread. The cables can be special ordered (takes about 2 weeks) from your HD dealer. You should thenbe good to go. I ordered the cable on-line from Chicago Harley-Davidson part number 32108-06.
TJRKC
03-08-2008 06:35 AM
oldfartjc
02-14-2008 09:26 PM
