Speedometer and Odometer issue
RE: Speedometer and Odometer issue
tcstd, i have not read all of your diy articles (my favorite area of this forum) but is there a prob with the synth 3 in the trans?
i only changed to it at the last interval, only bout 1000 mi ago.
hmmmm, now you got me thinking, went to synth 3, and thats when i had my speedo prob. GRRRRRRRR
"I'll bet you're using Syn 3 in the transmission too with all that metal on the sensor "
If you watch the magnets on the various sensors (VSS in the trans and the crank position sensor in the engine) you'll find some significant metal on them using the syn 3 which tells me there's some wear going on in there (more than normal in this case). If you switch to redline shockproof heavy as I did in the trans or even the Mobil 1 75/90 , you find very little on the next change when you go from syn 3 to redline. In your next change again, you find almost none at all. Conclusion here is that using the syn 3 , you get much to much wear in the trans backing up what I have been saying for a long time here.I don't recommend something for profit, I recommend it because I know it works. Some things are very obvious if we pay attention and see what we are looking at. Don't go by what some dealers tell you to use as they are selling the product and are more concerned about their bottom line. By the time you have repairs to your trans, more than likely your warrantee will be over by then so the dealer makes out here again. It equates to some who profess certain type of oil mainly because they sell it, not because they actually believe it is a superior oil to begin with which holds true with many oil dealers here too..
https://www.hdforums.com/m_273708/tm.htm
tcs, i read your article, as i have read quite a few of them
i have found this site to be like crack, now im started, cant stop
i take your words as law, and will change out the oil
its only got 5400 mi, and about 1000 since that oil change, so i should be kewl
since i stumbled upon this place, im here for a cpl hours a day, absorbing everything
since my scoot is out of warranty. i enjoy working on my own junk alot, have wrenched every
bike i've ever owned.
i will try the mobil 1 75/90
what do you recomend for the primary and the eng?
never mind, just found it in the diy
thanks again
rayn
thanks again
rayn
Ink, your problem sounds like the sensor. However, I read an article in a bike magazine a while back that addressed eratic speedomter problems. The author suggested using as start up procedure like this, turn on the ignition at the key and wait until the security light goes off, then turn on the switch at the handle bar and wait until the oil light goes off, then start the bike. His point is that the bike goes through a series of checks when the ignition is turned on and starting the bike during that process sometimes messes up the electrical. It sounds sort of silly, but I swear, that's what the guy said.
hey man,
I have a similar problem, but when I turn on the turn signal, the odometer flashes. My bike drains and kills the battery. The odometer works at idle, but when reved up, it goes blank. I ruined 2 batteries. I tried a new ignition module, speedo, voltage regulator, but nothing helped. any ideas, anybody? i am desperate. this has been 2 years now. Does anyone know how the bike will act if the stator is going bad?
thanks,
wayfat
thanks,
wayfat
wayfat, i see you are new here.
welcome aboard.
you can help everyone help you by giving some better details.
what bike
what year
what mods
that is a good start. there are lots of helpful knowledgeable people here, just give more info and you'll be on your way
good luck
welcome aboard.
what bike
what year
what mods
good luck
