Intermittant Engine Light
Old 04-04-2008 | 06:46 PM
kevdog's Avatar
kevdog
Default Intermittant Engine Light
I have a 99 RK Classic, fuel injected, recently bought it. Was running poorly, started hard, wouldn't idle, etc. and the engine light came on alot. Brought it to a trusted local mechanic, I like him, he's been around for years. After working on it he said he needed to replace 2 sensors (crank and cam) and cleared out the stored codes. Its now running fine, however the engine light still comes on and off at different times. I was anxious to the get bike back (was there a while) so he said the engine light coming on and off was the only remaining issue. He said it would take him a while to trace it down however the bike is all set otherwise, that it should run fine. Basically he's not a big fan of the pre-2002 FI systems, he said they were problematic. Anyone encounter anything like this before with the light coming on and off? I have the bike now but next time I need something done I'll have him continue to trace down what is causing the engine light to come on and off.
Old 04-06-2008 | 03:53 PM
kevdog's Avatar
kevdog
Default RE: Intermittant Engine Light
Ok, just checked for the codes and got them. When going through it I went through 10 readings, 7 were clear but 3 had codes. At the end it displayed "CAL 03".
Here are the codes I found, can anyone help with what they mean?
For the 2nd readings: D025E
For the 6th readings: D065E
For the 10th readings: D105E
All of them had an additional character on the end, it was like a capital "E" without the top bar. Like and "L" with a dash in the middle. Any ideas?
Old 04-07-2008 | 12:34 AM
Larry Hairgrove's Avatar
Larry Hairgrove
Stage III
Same year, same thing.Bike runnig like **** all of a sudden,Changed the throtle position sensor.$44 dollars later running better, but light stil on.Maby it will take us to drive 40 miles to reset the computer.Thats what it took on my truck.Let me know whats up bro if you fix it.Thanks, your pal Larry
Old 04-07-2008 | 09:32 AM
kevdog's Avatar
kevdog
Thanks Larry! I'll definitely keep you informed on how I make out, please do the same with me. Whata PITA.
Old 04-07-2008 | 10:18 PM
Larry Hairgrove
Stage III
My friend is making a new kit to get rid of the fuel injection and go back to carb.S and S carb like $300 dolars harley wants to sel you a new fuel injection for way big bucks.You cant get a new Harley w/carb any more.Harley is engineering how to suck more money out of our pocket insted of making a better bike, damn greedy basterds should have done more research before they came out with fuel injection,The japs ben doing it for years.Look at the V rod took Harley 100 years to figure out how to make a jap bike.Dont get me wrong love the bike but just dont like the people running the company.Later
Old 04-08-2008 | 07:29 PM
kevdog's Avatar
kevdog
Ok, I went and read my service manual and realized that I checked the codes incorrectly. I just "correctly" checked them and its coming back with one code, 42, which is for the Camshaft Position Sensor. I know both the Camshaft and Crankshaft sensors were just replaced. When I took it for a ride the engine light would come on for a while, off for a while, etc.
Any ideas?
RayDosch
05-15-2017 10:50 AM
Speedspeed
Exhaust System Topics
12-02-2016 01:10 PM
G wizz
07-29-2011 06:05 PM
harleyflo
06-16-2011 05:00 PM
joe v
General Topics/Tech Tips
05-02-2006 11:57 PM
