Fuel pump not working HELP PLEASE
Old 04-03-2008, 12:41 AM
leohd's Avatar
leohd
leohd is offline
Default Fuel pump not working HELP PLEASE
I switched tanks on my 2003 flht and dummy me pulled off the top tank assembly off and set it on the battery, it got a lil hot, when I reassembled the tank, I went to start the bike and it cranks but I don't hear the fuel pump and it won't start, all fuses are good, all connections are tight and connected how can I check the fuel relay or fuel pump before I buy parts I might not need. Thanks for any suggestions
Old 04-03-2008, 12:46 AM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Default RE: Fuel pump not working HELP PLEASE
The connector for the fuel pump has three spade termanils....some times when you slide in the male connector one of these spade will get bent down and not make contact, so check out the connector on the tank it's self first.
Old 04-03-2008, 12:50 AM
leohd's Avatar
leohd
leohd is offline
checked that connector 1st then I pulled to assembly back out and checked all the rest of the wires and they all look tight and fine
sepperl
07-19-2020 06:21 AM
Moboy
12-20-2010 12:07 AM
leohd
04-03-2008 12:27 PM
leohd
Exhaust System Topics
04-03-2008 10:27 AM
tmac5854
05-18-2007 04:19 PM
Quick Reply: Fuel pump not working HELP PLEASE
