stealer won't give copy of sert map
So I just got off the phone with the local stealer, asked if they will give a copy of map when they do a dyno, they said no there is a copy stored in the sert its self there is no reason you should need a copy, but to duplicate it and give it to someone else so we don't do that, is this true ?
RE: stealer won't give copy of sert map
I can understand their point, the map they loaded onto your ecm represents not only the dyno time you paid for but all the knowledge and skill of the tuner as well. Some tuners will give you a copy and some wont. If they dont I would confirm that they have retained a copy of your map so that should you ever need them to do more work on the bike they have a baseline to start from. It one of those things you really do need to confirm before you get any work done because if you dont like the answer you can always find a tuner who will give you a copy of the map. I guess a lot would depend on your bike. If you have a totally stock bike and the tuner set your bike up for say lower heat, then I bet he wouldnt give anyone a map as the opportunity to pass that map onto people with bikes just like yoursis pretty high. However if you have had head work, big bore, exhaust, air intake, new cams, change in compression etc., then its really a map that is only of any use to you and the arguement for not giving you a copy of the map really is pretty groundless.
I had the same thing happen and won't go back to that dealer for work anymore. They don't want you to see what the tuner did on that map. This leads me to believe they want you to be dependent on them 100% or they didn't do much of a real tune job. Either motivation would cause me to look elsewhere for tuning expertise.
ORIGINAL: theroadking
I think that I am going to do a latus map I like the fact that I have my map so if I need to tweak it alittle I can without having to to make an apointmen pay the stealer to fix somthing they should have been able to get right the first time. The more I read on these forums and the more I deal a hd service the more Im glad I can turn a wrench.
